I have 23 acres with about a 1 1/2 acre pond that is fed by spring and surface water runoff. With heavy rains, the overflow runs into a low area in some partially cleared woods behind my house. Problem is that this water stands in an area of about 1/4th acre and it seems to take a long time to drain back down. Bad problem with mosquitos, etc.
I had an idea that maybe I could pump this water back to my pasture to water garden or simply pump into pasture to dry up this area in the woods. Also thought that maybe I could pump the water back into the pond because the water level in the pond will go back down but there will still be water in the woods.
The distance from the water in the woods to the pasture is about 250 feet and the elevation is probably 4-5 feet. Distance from water in the woods back to pond is proably 400-500 feet and also elevation of 4-5 feet.
How could I best do this? I thought about laying some PVC pipe and would like to have some type of system where I could have some type of electric pump to pump this water back up the hill. I would like to put the pump near the barn which is about 100 feet from the water in the woods.
How would you go about doing this? Do you think this would work and is it a good solution to my problem of water in this low area and the resultant mosquitoes.
Thanks for any ideas or suggestions.
