JOAH
Hey guys, I need a little help just like the rest. I have a Ford 555c backhoe that I recently purchased. I went ahead and was going through it and decided to change the fuel filter and tighten some fittings on the injector pump; that's when I opened Pandora's box! Since then I have:
*Replaced fuel filter
*Cleaned primary
*Replaced throttle shaft and O-rings because it sheared off (yeah, I over tightened)
*Replaced fuel tube on top of pump- threads had been reamed off.
*Replaced check valve on injection pump
**Filled fuel filter and primary and bled from top of both by loosing and tightening small bolt on top of both
**Loosened fuel lines to bleed at top of engine one at a time while using palm pump
The engine ran great before I started but I can not get fuel to begin to squirt or drip out of any line at top of engine.
I have tightened everything and sprayed ether in air filter --it would turn over and try to run but never pick fuel up.
No fuel leaks now and I can feel/hear pressure from palm pump.
What am I missing?
*Cleaned primary
What am I missing?
