How to preform a transfusion on a IHI 35 S mini trackhoe?
   / How to preform a transfusion on a IHI 35 S mini trackhoe? #1
hardtime
Oxford, Ms
J/D 345
The machine in question is as IhI 35s smallish trackhoe w/ a nissan 4 cyl diesel . I think I have the cause pinpointed. Have owned the machine for about 5 years. It is an excellent digger especially for an older machine. No hyd, leaks, with exception of right side looking from back to front. And this is so small I just keep a close ck. on fluid level and top off as needed. The only drawback are the steel tracks across a manicured yard.
Several years ago I let the hyd fluid drain overnight then filled w / new fluid, ran it a couple days then changed it again. Very costly to say the least. I never expected to get all the old fluid / contaminates out but shortly after final refilling the fluid within a few hours again the fluid looked milky.
I'll be changing the fluid out prior to winter. Are there others with this problem, or have helped correct this issue? Any thoughts?
Hyster H225E Forklift (A47477)
Hyster H225E...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
Mobile toilet with shower (A53424)
Mobile toilet with...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
