joerocker
This is being discussed on the "operating" forum too but I thought I'd ask other "Chinese" owners... I have a Farmpro 2420, Jinma clone.
Should you operate your bush hog (a HEAVY piece of equipment) with the 3PH partially raised or lowered all the way?
I'm thinking that all that weight bouncing around CAN'T be good for the hydraulics and the seals. Am I right?
Now, to cut my field, I have my bottom links screwed IN completely (as short as possible) and my top link is screwed OUT to push the top of the cutter away from the tractor to angle the front up. It's OK but I still scalp a bit and dig some ruts with the sides from time to time.
EVERYTHING, all the links are VERY tight. Will this be a problem?
Another guy has drilled holes for the bottom pins that are lower down the brace. This will lift the front of the cutter and allow the links to be looser.
So, all you tractor experts...which is the right way to go?
