stumpfield
I plan to buy a 20' cargo container from someone's backyard. I need to figure out a way to load it on my flat bed trailer. Anyone done this before? Any sugguestions? I've seen the pro's do it with a tilt bed and pull it up with a winch but I don't have that kind of setup.
My initial thought was to drag it out in the open. Jack it up and back the trailer under it. Sounds straight forward but then I start thinking a little more and found a few problems. How do I jack it up in such a way it will clear on both side for the trailer to slide under. The container is 8' wide. The trailer deck is also 8' wide. That means I can't jack from underneath. I need at least 6" of clearance on each side... may be a little more as my trailer backing skill wasn't that great. Thanks for you help.
