How to identify my dump trailer
   / How to identify my dump trailer #1
garry
Bronze Member
Ohio
JD 1050
I have a 5x8 dump trailer with 24 inch sides. It has a monarch pump. I don't know what kind of a trailer it is and I don't know how to research it. I cannot find any numbers on the trailer. It may have been painted. I think it has a 5000 pound axle. would anyone know how I might research the manufacturer?
   / How to identify my dump trailer #2
If factory built it had a label on it probably around front end. Look on frame.
If painted over you probably can carefully remove paint off enough to read it. But do you have a title or bill of sale on it?
   / How to identify my dump trailer #3
Manufacture really dosnt matter. You need to measure the axle tubes and look the size up and compair it to tire load rating.
   / How to identify my dump trailer #4
Not perfect by any means but a 3500 lb axle will sometimes have 5 lugs and 5k have 6 lugs. 7K having 8 lugs. The lug bolt pattern circle gets correspondingly larger also.
As another poster mentioned check load rating on tires and inflation pressures though also!
Post a pic or two especially showing the rear tailgate as manufacturers seem to use different methods to mount them.
Maybe someone can identify it.
   / How to identify my dump trailer #5
Look on your title , it will state the manufacturer
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
Ford Tractor (A50120)
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
