How to get rid of bees?
   / How to get rid of bees? #1
MDSteve
Clements MD
Kubota 3710
My son found a large nest of bees last night and the wife wants them gone. He got stung about 8 or 9 times by what i think are hornets. They were about an inch and a half long black and white striped. They were also pissed off. They chased him across the yard and a few made it in the door before he could shut it. I asked him about the nest and he said they came from the ground. These weren't your everyday yellow jackets.
So here is the question what can I do to get rid of them?
Thanks,
Steve
   / How to get rid of bees? #2
gasoline does wonders for getting rid of this type of problem.
heehaw
I was thinking of gas or diesel out of a pump up sprayer.
Steve
   / How to get rid of bees? #4
MDSteve,
If they are the hornets/wasps I find, there is going to be an
above ground nest that is easy to destroy with an off the
shelf hornet/wasp spray.
I found a nest the easy way this weekend in my rotary cutter.
I happened to have just a little of the spray I used two years
ago. It foams when it sprays so it does a good job of
knocking down the bugs and keeping them from flying at you.
The wasps/hornets I have seen are building nests near the
ground, about 18-24 inches.... If it is a below ground nest
of yellow jackets, I don't have a clue how to find them the
easy way. I have found them the hard way twice and
really don't recommend this method! /w3tcompact/icons/smile.gif
Good Luck,
Dan McCarty
   / How to get rid of bees? #5
Deisel or kerosene will drop them faster than anything else I've tried, but are not the most enviromentally friendly things to use. If the nest is above ground, the bee spray works fine. Below ground I usually use small amounts of deisel applied sparingly. Best time to get the nest is a little after dark, as all the bees should be in the nest and settling down for the night.
   / How to get rid of bees? #6
Sounds like you have a nest of Bald Faced Hornets.
They are quite aggressive by nature and even more so
when distribed.
As already suggested, get a can of Hornet Spray from
Wal/w3tcompact/icons/smile.gifMart. I'd wait until dusk when the majority
of them are home and saturate the nest.
Then give it another shot in the AM.
   / How to get rid of bees? #7
A couple of times I have goten rid of them with a shop vac. Works best at dusk as the bees are returning and the noise of the vac seems to bring them out of the hole, so you seem to get them all in about 20 minutes.
   / How to get rid of bees? #8
Ground bees are the worst. Sparing use and bug spray be darned, IMHO--once you've found their hole, go out at night, pour about a pint of gasoline down the hole and light it, and enjoy the little blue flame. I'm sure there are a million reasons why this is a bad strategy, but it sure feels right to me!
   / How to get rid of bees? #9
What you describe sounds like what I call 'white tailed wasps'. They look like yellow jackets but the stripes are white rather than yellow. I have seen them nest in the ground and in sphere shaped nests in the barn and under the deck. I was stung once by one and that was enough. It felt like someone hit me with a maul. I give them a very wide berth. To get rid of them, I wait until night and use a wasp spray. One good shot is all it takes.
   / How to get rid of bees? #10
If they are in the ground and aggressive, I call them yellow jackets. I know there are lots of names, but that is beside the point. I do as you, and pour gas in the hole and throw in a match. Not a problem after that, unless there is a dry national forest nearby. Then I might think of another approach.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
Pallet of (6) 3 Phase Motors (A53117)
Pallet of (6) 3...
