how to get off old cement from cement mixer
   / how to get off old cement from cement mixer #1
diesel7.3
I have a stow cement mixer i bought used it has a lot of old dryed cement on the barrel outside and inside also on the wheel nuts can't change the tires on it because of all the cement on them .Does anyone know the best way other than sand blasting to get the old cement off the mixer.Any help would be great thanks.
   / how to get off old cement from cement mixer #3
Hydrochloric or phosphoric acid will remove cement (especially when coupled with scraping, hammering, brushing, etc).The solution can be relatively weak -- you just need to be carefull as to where you apply it:eek:
   / how to get off old cement from cement mixer #4
Egon said:
I agree, it's the fastest, easiest way that I know of. Once you get a few key pieces off, the rest sort of comes off real easy.
Eddie
   / how to get off old cement from cement mixer #6
Mythbusters tv show busted the myth that a stick of dynamite will do the job.
   / how to get off old cement from cement mixer #7
X3 = Hammer
Followed by air gun needle scaler if you're really fussy and maybe thinking about repainting and want virgin steel to work with....
**NEW TOOL ALERT**
Northern tool Item# 15763. 40 bucks. lol
   / how to get off old cement from cement mixer #8
I cleaned and repainted my Essick Plaster mixer with a angle grinder with a wire brush on it. Muratic Acid will cut it, its a slow process if you don't get most of the big stuff off.
   / how to get off old cement from cement mixer #9
I vote for a hammer, hit the metal though, not the cement. that will cause the metal to vibrate and make the concrete fall right off.
Aaron Z
   / how to get off old cement from cement mixer #10
Safety glasses would be a must.
12in Backhoe Bucket (A53472)
12in Backhoe...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
