Traction How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever
   / How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever #1
wesuri
pertrh,wa
lz804
there's levers below the draft but not sure of their use?
   / How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever #2
Hello wesuri, can you provide a photo of the gear stick layout and badging please? Also include a photo of the levers below the draft you are not sure of.
I am aware of an 8x2 and a 12x4 gearbox but don't recall a 12x12/ What country are you in as you may have different options to new zealand.
   / How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever #3
375 12+12 is common I Europe
   / How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever #4
2nd attempt at posting.
Hello again wesuri, I have been talking to an MF man.
With the gear stick in neutral, push the stick to the right, when you encounter resistance push firmly to the fight so you go through the detent . Shift the gearstick forward to engage H high( I believe you are in M range from your description) range, then return to regular neutral and you will have engaged H high range.
To down shift from H to M range repeat the above.
To go from M to L range , go through the detent and shift BACK to engage L low range.
The gears in the range change detent are from front to back H,high M, medium neutral, L, low.
NOTE there are H, M, L, light on the dash board to tell you what range you are in. It is quite common for these light bulbs to blow, especially with age.
Last Note, the gear linkages have a small needle bearing inside the gearbox that gets worn and falls off the shaft into the bottom of the gearbox. To fix this you will have open the gearbox up from the top.I was told it is a big job to unbolt all the stuff to get into the gearbox, and once there it is a simple job to replace the gear linkage bearing.
good luck.
and do give some feed back, that is how this site works.
good luck.
I would like to thank both replies and i was trying to get photos online but couldn't work it out.
I would especially like to thank redman as after following your instructions the penny finally clicked and I got it sorted!
Once again thanks to you both
   / How to get High gears on a 375 MF the badge at the front says 12 forword and 12 rever #6
Nice to hear it was just an unfamiler gearbox and not a broken part that was stopping you.
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
7021 (A50322)
7021 (A50322)
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
