How to fix "cage nuts" on IH tractor body panels?
   / How to fix "cage nuts" on IH tractor body panels? #1
Crashcup
Monticello, MN
'71 International 444
Hi, I've got an IH 444, but I imagine a lot of IH tractors use the same thing. The body panels fasten with bolts into captive nuts. Looks like square holes were originally punched in the sheet metal, then the nuts are pushed in and tabs bent back so it doesn't fall out.
Anyway, the square hole is what keeps it from spinning, but I've got one where the hole is stripped out.
Any good suggestions on a fix?
   / How to fix "cage nuts" on IH tractor body panels? #2
You might look for a clip nut. Much like a cage nut. but it is like a paper clip, and slides over the sheet metal.
   / How to fix "cage nuts" on IH tractor body panels? #3
1) JB Weld a new nut in place?
2) Grow a longer arm so you can reach the nut, while starting and tightening the bolt?:laughing:
   / How to fix "cage nuts" on IH tractor body panels? #4
G'day any good fastener supply should be able to supply you new ones they are not that uncommon.
Jon
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2239 (A51244)
2239 (A51244)
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
