How to finish off gated entrance with only 2 feet on either side?
   / How to finish off gated entrance with only 2 feet on either side? #1
Stringer
I have a "flag lot", my driveway is very long and skinny (500+ft x 20ft). I just installed field fence on the right side, and the driveway. I want to install an inexpensive 16' farm gate. This will leave me with approx. 2 feet on either side of the gate posts i'll need to fill with something. I know it's not much room, but id like to make the transition from gate post to field fence look really nice if possible. The wire stretched in front is temporary, and really looks like crap IMO. I have a temporary chain gate I installed today. There is also field fence on the left, it's just really old and difficult to see. How would you finish off this entrance, while using this gate? :confused: Thanks.
I was thinking maybe with PT timbers. set the gate posts and angle a few timbers inward to kind of funnel into gated area.
   / How to finish off gated entrance with only 2 feet on either side? #3
Stone pillars, automatic opener, alert sensor, and motion sensor lights. You can also make a metal fence out of steel square tubing and use it to support the farm fence gate.
Also, why use a farm gate? You can buy 8' aluminum gates that look stoic but sophisticated. By swinging one from each side, you can leave 1 closed all the time, 1 open all the time or both closed, with a final option to open them both if necessary. This works for me. (I can get you a picture if you would like to see). I use solar lights in the gate stiles for a little ambience.
BTW: A pickup or SUV goes thru an 8' gate space (with additional space of the hinge + latch gap) with about 2" to spare. This keeps the speeding down. This gives you the effect desired: "If you are looking for Trouble, You'll find it Here", or "Not Sure about Heaven or Hel*? Come on In and Find Out."
   / How to finish off gated entrance with only 2 feet on either side? #4
Are you in snow country or not? Where?
I think I would get some panels made to simulate the pipe and wire in the gate. To me that would dress it up the best, short of putting in an 18' gate. :)
   / How to finish off gated entrance with only 2 feet on either side? #5
This is what I was writing about. Outbound and inbound. The driveway alert is a Miltronics LR Deluxe infrared sensor. Good to over 1000'.
beenthere: im in florida. what kind of panels are you referring to? got a picture?
zzvyb6: thats a real nice gate you have. i like it alot. however i don't think it would mate well with my field fence and limerock drive, I think it would be too "dressy" and wouldnt match well (same with stone pillars). thats why i was thinking a wire mesh farm gate. My drive is 10' wide so no inbound/outbound, one way only. i think im looking for more of a ranch/rustic look.
   / How to finish off gated entrance with only 2 feet on either side? #7
Stringer
You showed a pic of a gate. I presumed it was the one (or similar) to the one you are going to hang across your drive.
My suggestion was to "make/build/have built" side panels to fill the gaps that match that gate so they have a uniform look across the full width.
Very much like the pics that zzvyb6 shows (which are very neat), and it adds to the good looks when the sides are of the same design.
   / How to finish off gated entrance with only 2 feet on either side? #8
What is the gate intended to keep out, or in as the case may be?
If you are only really concerned about vehicles, just plant new posts with 16' between them. If the posts are 12" in diameter, you will only have a 12" gap on either side. A Pedestrian could squeeze through, but certainly not a vehicle.
If you want more security, plant two 12" posts on either side and tie them together with all-thread and nuts/washers. A determined pedestrian will still climb the gate, but even bicycles will be excluded.
   / How to finish off gated entrance with only 2 feet on either side? #9
While you are thinking about what to do I'd hang something easily visible like a rag from that chain or it might decapitate someone. It nearly happened to me once.
   / How to finish off gated entrance with only 2 feet on either side? #10
If the gate and fence posts you have in now are wood, I'd keep it simple and use similar sections of wood post run horizontally between the gate posts and the fence posts. I also add a Diangonal wire turnbuckle running from the top of the gate post to the bottom of the fence post on the hinge side of the gate post (support the weight of the gate)
2006 CIMC SZJ9341TJZ03 20FT CHASSIS TRAILER (A52141)
2006 CIMC...
City of Tampa (1611) VIN: 1FTMF1CM1EFB40793, **Title MUST be transferred into buyer's name (A51692)
City of Tampa...
Caterpillar PS-150C (A50120)
Caterpillar...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
