How to combine MP3 or WAV files
   / How to combine MP3 or WAV files #1
rlk
Apex, NC
MF 35 BX 2200 1952 Farmall H
I used a cassette recorder to record a radio program this morning. In the middle of the recording there are a bunch of commercials that I want to get rid of.
I have created 2 MP3 files, one before the commercials and one after the commercials. Now I want to merge the two files into one file.
I also have the same two files as WAV files if that makes any difference.
Anyone know how to merge these files, hopefully with a product that comes with Windows?
Thanks, Bob
   / How to combine MP3 or WAV files #2
Hi Bob,
The best product for you would be the excellent "Audacity". It will do all you want and more. If you are trying to manage audio files, it is the best freeware program available.
http://audacity.sourceforge.net/
Specifically, open both of the files you want to "merge." Open the window of the first section, then position your cursor at the end of that file. Navigate to the second file, and "select all." Then copy that selection, and navigate back to the cursor point at the END f the first file. Do a paste, and you should have them all as one file. Then "Save as" under a new file name, and you are all set.
It does not matter if you do it as .wav or .mp3 files. The .wav will have a higher quality, but if all you are doing is listening, just go ahead and use the MP3 format. It is significantly smaller.
Hope this helps.
Hakim, that program worked great. Thanks very much for recommending it.
Bob
   / How to combine MP3 or WAV files #4
/forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
12ft T/A Park Dump Trailer (A52377)
12ft T/A Park Dump...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
