How To Clean out the Fuel Tank
   / How To Clean out the Fuel Tank #1
AndreaV
2011 Mahindra 3016
We purchased new in 2011 a Mahindra 3016 Shuttle We have had LOTS of issues with there being debris in the Fuel Tank like metal and plastic little pieces. We have gone thru LOTS of fuel filters and also had a repair guy try to remove as much debris as he could with tweezers. Now even after changing the fuel filter the tractor gets starved of fuel. I need to either purchase a new fuel tank or drain the existing fuel tank and find a way to really clean the inside. Does anyone have any experience with this issue. I would really really appreciate any help. Is there a drain plug on this fuel tank? (I could not find one) and I could use some help on the best way to remove the existing tank. The Fuel supply line coming out of the fuel tank does not allow enough to drain out the diesel.
Thank you for any help.
Sincerely,
Andrea
   / How To Clean out the Fuel Tank #2
Try to score a shop manual for your tractor. It should give the procedure for removing the tank. If you can remove the tank you can probably flush it properly, invert it, or whatever. If you can do that you'll probably not need a new tank.
   / How To Clean out the Fuel Tank #4
A vacuum cleaner with a long hose will suck out debris from the tank without removing it.
   / How To Clean out the Fuel Tank #5
How did you even get in the fuel tank? On mine, it has a plastic filter and then a screen in the bottom. I didn’t want to waste fuel looking in the tank but didn’t want to tear screen out either. I am going out and look at it again. It was about dark when I was working on it last night.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
