How to change gear oil in BX Bagger?
   / How to change gear oil in BX Bagger? #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
Hi guys! I just bought a used bagger for my BX. I got it mounted and leveled (+/- 3/16inch). I have not put on the chute and attached it to the deck yet. I want to change the gearbox oil first.
Anyone have pointers on how the heck to get at them and how to change the oil? My manual tells me nothing about access to the gearboxes.
Thanks for any help you may be able to give me!
   / How to change gear oil in BX Bagger? #2
I asked this same question with no reponse several week ago. I can tell you how to get to the gear boxes and that is to take off the long "L" shaped plate on the back of the bagger. Just start unbolting the bolts and keep going until you've got them all and pull off the plate. I found that I had to loosen the bolts that hold the main gear box on to slide the plate out. From there I couldn't really see how the oil could be changed.
2015 KENWORTH T800 DAY CAB (A48992)
2015 KENWORTH T800...
2006 INTERNATIONAL 9400I (A48992)
2006 INTERNATIONAL...
3 Point Hitch Receiver (A47371)
3 Point Hitch...
2010 HEIL TOKEN TRAILER (A48992)
2010 HEIL TOKEN...
Skid Steer Hydraulic Adjustable Pallet Forks (A47371)
Skid Steer...
2008 STERLING L9500 TRI AXLE DAY CAB (A50046)
2008 STERLING...
