how to change a pto clutch on a 2155 cub cadet.
   / how to change a pto clutch on a 2155 cub cadet. #1
Donnie55
cub cadet 2155
I've was mowing & stop for awhile and went back to cut again,put the pto on for the deck & it didn't come on the first time,but I push it in & out again and it came on.Since then about 2 weeks later,I started the tractor and then went to put the pto on and it did not come on at all. I've changed the switch and checked the 2 fuses,now I wondering how to change the pto clutch.Can you tell me how or did I oyer look something.
   / how to change a pto clutch on a 2155 cub cadet. #2
did you ever get an answer? I have the same issue on my 2165. When I first hit it "on" it kicks in. Then, after cutting it off (for whatever reason), it struggles to kick back in when I pull the switch. It does make a noise like it wants to. Thanks.
   / how to change a pto clutch on a 2155 cub cadet. #3
if your machine has an adjustable type PTO clutch, go to borg warner's website - should be able to d/l an adjustment procedure for your clutch...
4 Drink Hog Waterer (A50515)
4 Drink Hog...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
