DieselPower
Elite Member
- Joined
- Sep 30, 2006
- Messages
- 2,756
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
There was a comment made in another thread about how much of a PITA it is to figure out how much DCA/SCA you need to add to your coolant when using test strips. Personally I never really gave it any thought since I have a handy little slide chart that was given to me years ago when I worked for a International truck dealership. I guess it's one of those things you never realize how handy something is until you think about it.
In any case, I have scanned and uploaded pictures of the chart. The first two pictures are of the outside of the slide chart. The third and fourth pictures are of the internal slide card. The fifth picture is of what it will look like assembled. Please pardon the greasy finger prints, it's seen a lot of use over the years.
Probably the easiest thing to do is print out the first four pictures. Just right click over the picture and then select print. Trim the pictures out. Cut out the viewing windows in the first and second pictures and a slot at the top to grab the internal card by. Tape the first and second pictures together along the left and right sides. Tape the third and fourth pictures together back to back (be sure it is cut small enough to slide into the previously assembled outside). Now just slide the number chart in the outer body. Using a DCA/SCA test strip take the reading you get with it and slide the internal card out until that number is showing. Find the approximate capacity of your cooling system and the number below it is the amount of DCA/SCA you need to bring it up to about 3.0.
Moderators - Feel free to make a sticky out of this to make it easier for people to find.
http://www.tractorbynet.com/photos/data/500/DCA1.JPG
http://www.tractorbynet.com/photos/data/500/DCA2.JPG
http://www.tractorbynet.com/photos/data/500/DCA3.JPG
http://www.tractorbynet.com/photos/data/500/DCA4.JPG
http://www.tractorbynet.com/photos/data/500/DCA5.JPG
