Posthole Digger how to build this
   / how to build this #1
chevyman003
i heard you can use a differtial from a vehicle to make a post hole digger,but want more experiences from you people,,,thank you
   / how to build this #2
No real standard way to do it. You just have to use what you have avaliable.
For starters, you need to buy/comeup with/make an auger.
Then you need a rear end. You will cut one axle tube off and remove the axle. Then you have to weld the spider gears together to force the axle that is left to be the one that turns. The PTO will drive the pinion, and the axle that is left needs to be cut down, and adapted to the auger.
This will also require a bastard size PTO shaft joint most likely.
And it is best to find a rear axle that has inboard seals and not outboard wet bearings. Otherwise, it wont hold lube in the diff.
Honestly, this day in time, it would probabally be cheaper in the long run to just spend $500 and buy one. Unless you happen to have a rear end, auger, AND pto that will already work. But to just buy a PTO shaft and auger you would probabally already be close to new PHD price.
   / how to build this #3
They are not hard to make. Buy the auger & cutter, a PTO and slip clutch from a wrecked machine shouldn't be hard to find.
Not sure what LD1 means by a bastard size PTO shaft joint.
I used one from a wrecked header (combine) it wasn't a problem.
   / how to build this #4
I'm guessing it makes a difference which axle tube gets cut off, based on direction of rotation. It'd be kinda embarrassing to get it all done and see the auger run backwards. Just one of those small but serious details that could get overlooked in the heat of battle.
   / how to build this #5
This thread is 4 years old.
What I was referring to on pto joint sizes is a u-joint meant to connect two yolks of different sizes. IE: different cal diameters and different length needed on the same u-joint
Hyster H225E (A47384)
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
