Oil & Fuel How to bleed fuel line.
   / How to bleed fuel line. #1
supersport
I misplaced my manual of my 6000 2WD and desperately need help on how to bleed the fuel line. Three weeks ago the engine is acting up, it felt likes the power is not there and the engine sounds likes it ran not on all cylinder. I suspected that the water in the fuel is the reason, so I drained some fuel out of the fuel filter bowls. This weekend I tried to start and the engine fired up for like two seconds and died. Pease help me on how to bleed the system. Thanks.
   / How to bleed fuel line. #2
I had a similar problem with my 2615. It would start and idle but couldn't bring up the RPM to use it. It would stall out. My problem was a partially plugged fuel filter. I valved it off, replaced the filter, cycled the key a few times so the electric fuel pump could refill the line and it started right up. I'm not familiar with the 6000 but don't you have an electric pump as well? The pump should prime the lines with enough pressure to force any air through. If you suspect water in line did you add some Power Service to the fuel to remove water.
   / How to bleed fuel line. #3
Supersport
If you would like to give me a phone call I will try to help you with it.
Thanks, I will call you soon.
   / How to bleed fuel line. #5
You may also want to check for trash in the fuel lines and tank.
   / How to bleed fuel line. #6
I would have to go with, check the fuel lines for trash. On our 3505 just about the same trouble. The fuel tank had been coated with some kind of finish that had started to come loose. This was plugging the fuel shut off valve. We cleaned the tank as best we could, but the finish kept plugging the valve. We made a fine mesh screen about 3" long inserted it into the valve fitting in the tank, this fixed the trouble (for now) has been about 6 mo. ago. TB
   / How to bleed fuel line. #7
We had a customer one time that had a large piece of clear plastic inside his fuel tank that would cause his tractor to randomly die because the piece of plastic would block the fuel lines. We also had another person who had some kids put a handful of rocks in his fuel tank because he didn't lock his fuel lid.
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
