How to adjust the idle
/ How to adjust the idle #1
whynot162
Amboy WA
Rhino 324
This tractor has never idled at minimum throttle. I have to have it about 1/8 of the way open. but seems to run fine. Also there is no fuel in the return lines from the top of the injectors.
So how do I fix this? or does it matter? The return lines on top of the injectors that do not have any fuel in them return fuel to the tank, and to the preheater for the engine.
My ford 6.9 and 7.3 IDI had tons of fuel in the return from the injectors.\
thanks
doug
Maybe the fuel delivery ammount needs adjusted?
/ How to adjust the idle #3
The the return lines from your injectors are just leak-off lines, so don't expect any fuel there until the injectors become worn or damaged.
The three basic types of fuel systems include pump-line-nozzle (PLN), unit injector, and common rail. On your tractor you have the pump-line-nozzle, or more precisely, pump-line-injector. Normally on these tractors the fuel return line from the injection pump is routed through this circuit on the way back to the tank, so then you must have two fuel "return" lines?
Assuming you have a tach on your tractor, what is the low idle speed now?
There is no tac.
when I lower the engine speed with the manual throttle it goes low and dies. This is frustrating, having to restart all the time.
/ How to adjust the idle #6
There is no tac.
Then do as Tommy says. You can see which is the low idle adjustment by observing the linkage when you operate the throttle. Also, the low idle stop will not have a tamper seal on it.
You also need to do some re-plumbing of your fuel return system to make your pre-heater work. It won't work without fuel in it.
John Deere Wheel Loader Forks (A60462)
John Deere Wheel...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
IREV HIgh End Electric Scooter (A60463)
IREV HIgh End...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
