How to adjust L3800 HST neutral?
   / How to adjust L3800 HST neutral? #1
Rail Dawg
Anyone know how to adjust where neutral is on the L3800 HST pedal? The tractor shuts down when I get off the seat and I've isolated it down to the safety switch thinking the tractor is not in neutral.
Any help appreciated!
Still looking for an answer to this... Is there a way to adjust the HST neutral point so the safety switch will allow the tractor to start and then not shut down when you get off the seat?
I put a piece of tape on the moving part that contacts the safety switch and that did the trick. However I'm looking for the proper solution rather than jury-rigging it.
Thanks.
   / How to adjust L3800 HST neutral? #5
I take it you don't have a shop manual. The next best thing is download a parts manual and look it over real good. With one you see how it works if you look at it long enough. I don't have a parts manual for your tractor otherwise I would send it to you. Try kubotabooks.com
No I don't have the shop manual but I know I need it. I found one at Messicks and will need to order...
John Deere 6115D (A50120)
John Deere 6115D...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
40' High Cube Four Multi Doors Container (A47384)
40' High Cube Four...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
2006 International 9400i (A52748)
2006 International...
