geezer32095
I need to adjust the pressure relief valve located in the diverter/manifold block. From a different forum I know I need to attach a 3000psi gauge, and the relief is usually 50 to 100 psi below the max pump pressure, which is 2,133psi. Is it just lowering the spring tension & if so any idea on how many turns for a given amount of reduction?? Or just trial & error??
