How to add loader to L3540?
   / How to add loader to L3540? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
hi, I'm sneaking in here from the Coyote forum.
I'm looking at an L3540,, 2010, without a loader.
What does it take, aside from the loader ( LA514) to install the loader?
They mention a quick attach coupler, optional, J2513, what is that and is it needed?
It seems the loader cont4rol and the hydraulic hoses are already there, is that correct?
Thanks,
Mike
   / How to add loader to L3540? #2
Generally speaking, it takes about $4000-$5000 .. the LA514 isn't common, usually the 3540 has an LA724 loader. The quick attach coupler may be for skid-steer type implements as opposed to pin-on ones.
Sean
Thanks, I know nothing! I just saw a picture somewhere of the 3540 with a LA514 loader...
Mike
   / How to add loader to L3540? #4
You will want the quick attach coupler. It makes taking off and putting on attachments much easier like pallet forks or a grapple. Actually, I'm surprised it's still considered an "option" and not standard on all loaders.
   / How to add loader to L3540? #5
I installed my La 854 loader on my L5740 myself... Would plan on buying a metric tap to clean out the holes before you try to install they loader brackets.. Took a me a few hrs but not bad to do. I had the loader deliver to my garage.
   / How to add loader to L3540? #6
If you are going to do this, install the 724 for sure! The 514 is half the fel that the 724 is!
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
