how to add air to tractor rear tires with ballast
   / how to add air to tractor rear tires with ballast #1
bfknouse
Medford,NJ
Ferguson F40
I have a Massy F40 with rear tires that have ballast what is the correct way to add air?
   / how to add air to tractor rear tires with ballast #2
Its easier to do when the valves are at the 12 o’clock position.
   / how to add air to tractor rear tires with ballast #4
^^^^^This. You may get a little wet but it won't take much air at all since most of the tire is filled with ballast and you can't compress it.
   / how to add air to tractor rear tires with ballast #5
I had my tires filled and tried to check the pressure. Even with the valve stem at 12 0'clock I got wet. It turns out one tire was over filled. I simply took the hose off a hand pump, attached it to the valve stem and drained about a gallon of fluid into a pail. Now both tires can be checked and adjusted 'dry'. I leave the gallon in my unheated garage in a container and shake it on cold winter days to see if it is getting slushy. Also, I used a cheap pressure gauge that first time - glad I did not fill my digital gauge with antifreeze.
   / how to add air to tractor rear tires with ballast #6
Either use an air gauge that can take water or use the Harbor Freight one that I like that has a long extension on it with built in gauge. Just blow any moisture out when finished.
Ralph
   / how to add air to tractor rear tires with ballast #7
Some say to give the tire valve a blast of air to clear it of juice before using a tire gauge so that gauge doesn't get contaminated.
   / how to add air to tractor rear tires with ballast #8
Everyone, thanks for the tips as I have been sprayed with "beet juice" a few times (pretty sticky).
Does it help any to jack up the tire off of the ground or is that a waste of time and effort?
KC
Thanks it worked
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
