How steep is too steep?
   / How steep is too steep? #1
QwikDraw
Platinum Member
North East
Timber King TK711
I have to bid a job with 45 degree slopes on the back side of dikes.
Will the engine be OK if I mow straight up and down the slope? I am worried about the oil sump sucking air and cooking the motor?
This is rotary work not mulching.
   / How steep is too steep? #2
I've mowed some 45 deg slopes with the Fecon on the 4810...was only a short pitch- say 20 ft up...machine seemed fine- but not sure how you would be with a longer pitch...give the tech guys at ASV a call...I have them on speed dial...ask for Tom in service...he seems to know the Cat/perkins engines well.
Thanks mate.
These slopes are 100 feet high +/- and I'll be on them for 2-3 days.
I will give Tom a call tomorrow.
I can't figure how to bid this one so I just pulled a number out of my...hat.
   / How steep is too steep? #4
If you had a mechinical oil pressure gauge you can see when the pump is starving for oil. I don't think I trust an idiot light for this application. We work grades of a little steeper then 2 to 1 with a dozer with out a problem but your getting to the limit of what even a dozer is going to like at 1 to 1 slope are you sure they are not closer to 2 to 1 most engineers are would not consider 1 to 1 stable. How are planning to get back to the top with out a winch tractor?
   / How steep is too steep? #5
I would have to agree. 100% slope is very very steep and a rubber track machine will struggle to climb that type of grade. I did some work on 50-60% slope in NM and my steel track crawler with single bar pads was scratching and clawing to work the material.
   / How steep is too steep? #6
Most engines are rated for 45 degrees intermittently up and down and around 25 degrees side to side.
PumpJack Brand Pump Jack (A53472)
PumpJack Brand...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
40' CONTAINER (A51248)
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
