How soon after the break in period
   / How soon after the break in period #1
Steve_Miller
Veteran Member
Nova Scotia, Canada
2006 Kioti CK30HST
should I use synthetic oil in the engine as well as the HST? 50hrs, 100hrs...?
Thanks Steve
   / How soon after the break in period #2
can't speak for the HST, but use it right away in the engine
   / How soon after the break in period #3
Hi, Just wondering what kind Synthetic oil will you be putting in your Bota?
At my 50 hr service I also am thinking about using Synthetic, So many to choose from, so many opinions also what weight? Thanks Tom
   / How soon after the break in period #4
Don't use Synthetic oil too soon. It's best to use regular Engine oils for the first 500 hrs. so the rings can seat for optimal power, Then start the synthetic oils. I prefer Delvac 1 made by mobil for a synthetic engine oil.
As far as hydraulic oils I have no knowledge of the synthetics being better than the regular.
Remember, this is just my Diesel mechanic's opinion, Don't try this at home and all the exclaimers that I haven't thought of:)
David
   / How soon after the break in period #5
Your diesel mechanic is wrong. Instead of 'old wives tale' that's an 'old mechanics tale'.
There are plenty of vehicles that come direct from the factory with synthetic oil. Does anyone think the engines sit running on a dyno for 500 hours? 100 hrs?
Also, there are plenty of threads in this forum about the benefits of synthetic hyd fluid. The issue isn't whether syn fluids are better, they are. The issue are (1) Do YOU operate your tractor in an environment or in a manner where you can reap those benefits and if so, (2) Is it worth it to YOU.
If I lived in Nova Scotia and had to use my tractor in the winter, I'd switch to synthetic fluids at 50 hours. Heck, I live in PA, and have to use my tractor in the winter. I switched to syn long ago.
   / How soon after the break in period #6
MikePA, Are you a diesel mechanic?
David
   / How soon after the break in period #7
   / How soon after the break in period #8
This comes from the Royal Purple web site in the FAQ section.
"Can I put Royal Purple into my brand new car?
Yes. Royal Purple currently offers many viscosity grades of API Licensed Motor Oils. To allow for proper break in of the engine, Royal Purple recommends waiting until the manufacturer痴 first scheduled oil change or a minimum of 2,000 miles in new gasoline engines. Allow 8,000 to 10,000 miles before using Royal Purple in diesel engines."
   / How soon after the break in period #9
I put full synthetic in all my newborn 'Botas with 50 hours on the clock and then changed out the tranny fluid to full synthetic at the first specified change, but that was many thousands of hours ago.
   / How soon after the break in period #10
I changed over my JD 2305 to Amsoil Synthetic Heavy Duty Diesel Oil and Synthetic Tractor Hydro Fluid both just shy of 50 hours. I stuck with the JD Filters as I was one of the fortunate customers who received a coupon for the free JD Filter Pack. I also run Sythetic in my 04 Bombardier ATV, 06 Ram, 06 Grand Caravan, Generac Generator, Briggs Power Washer, and my 4 stroke weedeater....now that I look at it, that's quite a bit of oil....
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
