How should I plumb a backhoe?
   / How should I plumb a backhoe? #1
Cold Camel
Yanmar 1110D
I have a shop built backhoe with two 3-gang spool valves in series. I haven't put in much seat time but the valve placements don't make sense.
I know lever location/function is a matter of preference, but I was hoping more experienced operators get me started right.
The outer two levers should be stabilizers, with push being down (right?). Presently fluid flows L>R (sitting at controls, facing rear of tractor) and controls are swing>boom>dipper>bucket.
Does the order make sense?
Secondly, what should push do for each? Clearly boom push should extend boom, but what about the others?
I don't know when I'll want to pull/push two levers simultaneously with the same hand, it would be a shame if one lever were reversed or moved apart. I would think I'd want pull dipper and bucket to bring in both as I scoop, it doesn't do that now.
Right now I'm baby digging - engine at slow idle, rarely use full stroke, going for precision not speed.
Please advise. And if there are digging techniques to match various valve placements, please send me to a tutorial(s). Thanks.
Cold Camel
Magnificant reply. Hours of research later I've decided L>R Swing>Boom>Dipper>Bucket with pull = up/in/curl. Options are nearly endless, but that's what works for me.
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
