How often do you powerwash your equipment
   / How often do you powerwash your equipment #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I love putting a way a clean tractor but it is just not practical to powerwash it everytime I use it.
Today I was moving around manure and so there is a lot sticking inside the bucket and outside on the QA coupler. Working in the same thing tomorrow as well so I figure I'll wash it off once that job is done.
I've been trying to powerwash my old tractor and rotary cutter after every cutting (once every 5-7 days - I do rotational grazing and mow weeds after moving the cattle out of a paddock). That too gets tiresome.
Curious to hear how often you guys wash your equipment. How much harm am I doing leaving some manure stuck to a bucket or other organic debris stuck to a rotary cutter? Of course the rotary cutter will get washed well before storing it for the winter.
   / How often do you powerwash your equipment #2
Pressure wash tractor once a year on average. Use garden hose maybe 3 or 4 times a year on tractor, maybe twice a year on my tiller, rotary and finish mower. If I worked in manure or anything else that would eat metal I would rinse more often !!
   / How often do you powerwash your equipment #3
My tractor gets pressure washed 2 to 3 times per year.
I pressure wash the attachments once per year at the end of the season before they are put away for the winter.
   / How often do you powerwash your equipment #4
For some reason my machines love mud. I believe there are little dwarfs that get my machines out at night and have mud bogs:laughing:. I power wash quite a bit, IMO it is part of proper maintenance, how could I find an issue if I can't see it{??}.
   / How often do you powerwash your equipment #5
I pressure wash as needed and just before I grease the FEL and BH.
   / How often do you powerwash your equipment #6
I power wash several times a year. Usually when I have the power washer out for some other reason. Once I string all those hoses I generally just wash everything in my path.
   / How often do you powerwash your equipment #7
Pressure washing is H E L L on any equipment, especially equipment with oil filled gearboxes and seals and bearings and all those things that moisture can destroy.
I wash with a garden hose to get the crud off, and pressure wash maybe 2 times a year. I NEVER pressure wash any haying equipment, my bailers have never seen a pressure washer, I just blow the chaff off, grease, check parts for wear and call it good.
I wash my mower decks, pull the blades and sharpen or replace prior to winter storage and coat with slip plate.
Glad I didn't buy your trade-in. It is probably heading for component failure from moisture ingress at some point in the near future.
   / How often do you powerwash your equipment #8
i don't own a pressure washer, so none of my equipment has ever seen anything more than about 40 psi from a hose nozzle. That's the way it's been for over 30 years know. I worry more about the salt in winter, when it's too cold to wash, but just around freezing inside where the tractor and gator are stored.
   / How often do you powerwash your equipment #9
Let me know if and when you sell equipment, I'll consider yours.......:D
I actually found that out the hard (and expensive way). I used to pressure was my big round bailer to remove the chaff and I compromised the upper roll bearing (got water ingress from the pressure) and had the bearing sieze in the field. I had to rent a bailer and then replace the bearing, the cross shaft, the spacers and one roll belt to the tune of about a grand for parts plus the day rental. I could have easily set the bailer on fire if I hadn't been watching and saw the smoke from the frying bearing/slipping belt.
Manure might fade paint in a bucket but it's a bucket. The paint just keeps the rust at bay. That's it. Show me a commercial unit with paint on the bucket and I'll show you a lemon.:laughing:
Clean and purty is for the Caddilac and the motorcycles. I prefer to put away a dirty tractor/implements. I know they were working......
   / How often do you powerwash your equipment #10
We have never used our pressure washer on any of our equipment. We use compressed air or leaf blower and then maybe a garden hose.
I never used a pressure washer on my motorcycles either, just soap and elbow grease.
I may not be doing it right, but we have some pretty old stuff still running fine.
I gave up working with cows many years ago, so that may be a different thing.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
Galvanized steel fence (A53424)
Galvanized steel...
2014 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A53843)
2014 GENIE GS-2632...
