How Much Weight????
   / How Much Weight???? #1
Carl1
Dayton,Ohio
IH 574 and IH424,Ih3414 loader
I have a 3 point drum mower(1200 pounds).
How much weight do I need to counterbalance the mower
any advice will help.
p.s. IH 574 tractor
   / How Much Weight???? #2
That tractor has a good base weight although the base design is mean't for a loader meaning light in the front end depending on the front axle used. I'd try it first and see what you need to hold it down or stable.
   / How Much Weight???? #3
What brand didja get? I just got a CCM 165, I am mounting it on a D-10 Allis, and I'm thinking I need a Wheel weight or 2 on the left wheel, but front to back seems OK.:cool: :cool:
I went with a Reese 2070. so far it works great I mounted about 200lbs of weight up front.
by the way when learning to use it I found that it will cut chain link fence without a problem!!!!!!!!
   / How Much Weight???? #5
Also, when cutting a cow pasture, it will flip Sh*t at you faster than a cow with the runs!
Case IH Patriot 3250 (A50123)
Case IH Patriot...
City of Lakeland (A51691)
City of Lakeland...
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
2007 Mack 600 Day Cab Winch Truck (A53117)
2007 Mack 600 Day...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
