Mowing how much rpm for mowing?
   / how much rpm for mowing? #1
bellweather
Platinum Member
Western MA
Kubota BX22
I have a BX22 with MMM and I think the manual says to run at max rpm when using the mower. Is this correct? My tractor doesn't have a tach but I've been mowing at around 3/4 throttle. Any words of advice?
   / how much rpm for mowing? #2
I always run my riding mowers at max when mowing. I always run my tractor at PTO speed when mowing. There are others that say to just run enough RPM that is necessary to run the mower well. Saves fuel and wear and tear on the equipment they say. I can't argue that. I do what the owners manual tells me to do. They would know better than me. This has always worked for me.
   / how much rpm for mowing? #3
I run mine up to WOT then back it off just a smidge...Not the most scientific approach but it's what I've done for years.
Don
   / how much rpm for mowing? #4
Don
My BX2200 manual says about 3050 for the MMM, which is just a smidge below WOT. I always laugh when I read "3050 rpm" because there isn't a tach so I guess I'm supposed to count!:eek:
   / how much rpm for mowing? #5
That is funny!
Don
   / how much rpm for mowing? #6
WFO or you will be on here asking why the motor is over heating and complaining that the motor did not last near as long as you hoped.
   / how much rpm for mowing? #7
So, WFO=3050 rpm?
   / how much rpm for mowing? #8
Don
When I had a B7100 without a tach, that's exactly what both the dealer and a Kubota factory rep told me to do. Wide open should be just a couple of hundred rpm more than the 540 PTO speed.
   / how much rpm for mowing? #9
So, WFO=3050 rpm?
I just looked everything up in my manual. I don't know about the BX22, but for the 2200 it is as follows:
Rated Revolution (WOT or WFO)=3200 rpm
Rear PTO=3068 engine rpm
Mid PTO=3125 engine rpm
3068 and 3125 are both pretty close to 3200. Countin' that fast, I'm bound to be off by a couple of detonations:D
   / how much rpm for mowing? #10
If your blades are nice and sharp, chances are you won't need full throttle. When your blades get dull, increase the RPM until you get an acceptable cut, or sharpen the blades. The slower the blades turn, the longer they stay sharp. You won't be able to back off too much on the RPM, because it won't cut very well. But you will be able to save some fuel and some wear and tear on your engine and mower.
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
2011 Chevrolet Equinox (A50324)
2011 Chevrolet...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
