How Much Rock?
   / How Much Rock? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I dunno nuthin' 'bout calculatin' no volumes, so here goes......
I have an old cistern that I'm considering filling in. Reasons aren't really relevant to the topic.
It's roughly 16 feet deep and 8 feet in diameter, rounded at the bottom and top. Consider something a bit larger than Dense Grade. About how much rock should I expect to use?
   / How Much Rock? #2
I will give it a shot. The formula for the volume of a cylinder = V = pi*radius[SUP]2[/SUP]*height.
In your case, V = pi*4[SUP]2[/SUP]*16 = 804 cubic feet. There are 27 cubic feet in a cubic yard, so 804/27 = 29.8 cubic yards.
Steve
Edited to correct math error.:ashamed:
   / How Much Rock? #3
It makes a difference if the space needs to be filled without any voids...for instance sedge stone that is typically used for things like riprap etc. may suffice and will not take the full volume calculated etc..
   / How Much Rock?
No, in fact I don't want it packed solid, hence the desire for something a bit larger than Dense Grade. 1-2" rock should do nicely. I'm afraid that dropping something as big as riprap 16' would possibly crack the concrete bottom.
   / How Much Rock? #6
I’m guessing 2 tri axel loads and a smaller truck load using the previous posters math of 29.8 yards.
   / How Much Rock? #7
It will be at least one good tri axle dump load. Start with that.
My experience with materials like that is that you never know how it's going to lay until you pour it out. You do the calculation like SMStonyPoint did -- 30 yards -- and you give that number to the guy when you call to order the material. Once he's there you tell him to keep the motor running while you figure out whether you need more. He should know that when a customer says they need 30 yards they need somewhere between 20 and 40.
   / How Much Rock? #8
Without more information...why not use (much cheaper) clean fill rather than gravel?
   / How Much Rock?
^^ Because I want to be able to draw water out. The plan is to set a 6-8" pipe down the center and surround it with rock. The bottom few feet of the pipe would be perforated to allow water in but not rock. I'll drop a shallow well point in the pipe, so I don't want mud or sand in there. The cistern is old, cracked and leaking, so rainwater settles int to it. I need to be able to pump that rain water out to keep the surrounding ground dry. If it gets full and seeps out, I have a giant muddy mess next to the house.
That will also give me an emergency water supply in some sort of disaster, though it will require boiling or other treatment.
So, why fill it at all? Because it's cracked and I don't want to risk it falling in on itself.
Rock will prevent collapse, but allow water collection.
   / How Much Rock? #10
Roger that...what we call "sedge stone" (from 2"-3" all the way to 6"-8") is used to fill obsolete dug wells and bored cisterns etc...
FWIW...with a high slump mix...concrete can be poured over the top 6"-12" to make a solid lid...the high slump will prevent it from falling through any voids...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
Duetz Power Unit (A50120)
Duetz Power Unit...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
Skid Hydraulic Hose Fittings (A50775)
Skid Hydraulic...
