How Much Rebar in Pond Masonry Wall?
   / How Much Rebar in Pond Masonry Wall? #1
zeuspaul
North of Escondido, San Diego
Kubota L4330****RTV 900
I'm building a koi pond. It is dug into the side of a slope. The outer wall is about thirty feet long concave inward. This outer wall will be about five feet high and built of 8 x 8 x 16 concrete block and then waterproofed.
The wall will be backfilled about two thirds of the way. The upper two feet or so will have no support from the earth.
Should I run lateral rebar in every course? Two twenty foot sticks overlapping ten feet in the center? Or can I get away with rebar in every other course? I'm planning on using 5/8 in rebar. Would 1/2 be adequate?
Does the bottom course need rebar? It will be backfilled with concrete.
How often should I drop vertical rebar? Every third hole?
Zeuspaul
   / How Much Rebar in Pond Masonry Wall? #2
You should run "Durowall" or galvanized masonry wire reinforcing horizontally every other course.
Vertical rebar typically would be every 3rd cell [24" oc] with #4 or #5.
If this is holding back earth you should consider going with the heavier wire and rebar or using wire every course and #4 every other cell. YMMV!
On edit: The website below has some interesting seismic stuff, since you're in California, but I'm not sure of the applications. I would cut and bend the wire reinforcing to the curve of the wall, and overlap the ends. Also, if I am imagining this correctly, the curved wall will have a lot of force channeled into each end - you should consider doing some heavy piers at the ends, filling all the cells with concrete, to anchor the thing. Think of your wall as a sideways arch.
Dur-O-Wal Single Wythe Systems
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
2009 Lexus RX 350 SUV (A55758)
2009 Lexus RX 350...
