Without basic information, there's no way to respond. Is the well pump 110v or 220v, and what is its' amp draw (one can add at least a 1/3 more for the start-up load)? I've a 3500watt Honda, and it can handle 1 of my 2 well pumps, the one purposefully kept to 1/2 HP, 110 v and 12 amps (specifies 12 running, 20 start). That pump goes to my garage/apartment, and for modest irrigation. The other well has a 1HP pump at 220 volts and 15 amps (running), and the circuit breaker on the 3500watt generator trips when connected to that circuit --- so I need to bring in my 6500watt Honda to handle that one (which, when I ever get it built, will be for my main house) - but, since I'm not interested in timing the on-off cycles of the various electrical draws in my house (e.g., can't run well pump at same time as 2 refrigerators, a microwave, lights and so on), I'll upgrade to a 15KW built-in and propane powered unit when I move in.
