How much front weight should I need?
   / How much front weight should I need? #1
Anonymous Poster
Epic Contributor
I own an Iseki TS 2205 2wd tractor. When I put my 5' bush hog on the 3ph I loss control of my steering wheels, even if i put just the slightest lift on the mower.
My question is would 125 pound be enough weight on the front end. My bush hog is not light weight but it isn't a heavy weight either. I would guess it weighs about 500 pounds. I can lift one corner by myself when I am mounting it on the 3ph.
Thanks,
Don Worrell
   / How much front weight should I need? #3
Just add weight until you have enough. 125# may not be enough, by the way you describe how light the front end is now when picking up the mower. But it is a good amount to start with.
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2013 FORD F550 SHUTTLE BUS (A53426)
2013 FORD F550...
Case 1083 20ft Corn Head (A53473)
Case 1083 20ft...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
2013 E-One 95FT Ladder Fire Truck (A51692)
2013 E-One 95FT...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
