How much for that rim??
   / How much for that rim?? #1
dogbreath108
Bronze Member
Check out this one...
I have complained in the past about the price of Jap tractor parts and I expect to pay a little more..
just priced new 10x28 rear rims. These are for a 2120 and are just the outer rim, NOT with the center disc. Average price of a 10 or 11 x 28 rim with the common 6 loops is about $130 aftermarket, $250 dealer. The compact 2120 uses 8 "S" mounts and not 6 loops. Otherwise its the same rim.. Are you ready for this one..... $1000 .... No not with a tire, just the outer rim $1000.00. I just can't believe it.... Makes me a little sick...
   / How much for that rim?? #2
Check on ebay under tractor parts, then under wheels and tires, there is a place out of tennessee that will sell a (I think an actual set of tires and rims) for Ford tractors, I do not remember but I think they are 8 hoops.
Are yours 8 hoops evenly distributed or are they 8 hoops at basically four points? You might think used rather than new. Google Sikeston, MO and tractor parts.
   / How much for that rim?? #3
I feel your pain. Do you just need a replacement of are you converting from Turfs to Ags?
I have R-3's on the back of this one and was thinking of getting a set of R-1's for winter. I tried with the place in TN with no luck. If I can find the "S" mounts, I am thinking of buying a set of 6 or 8 loop cutting them off and welding on the two hole "S" tabs. I shouldn't be that hard as the center disc would be the jig. I'm still left with finding a set of 16" rims for the front, which is turning to be impossible...
CONTACT INFO (A53084)
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2017 Vicon 764 (A50123)
2017 Vicon 764...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
