Loader How much does a B26 bucket hold?
   / How much does a B26 bucket hold? #1
Carl Bert
Platinum Member
Rockland county, New York
Kubota B26, John deere X595
I just had a load of topsoil delivered. Its supposed to be 18 yds, but looks more like 10. I figure if I count the amount of buckets I fill I can get a pretty good idea of how much is actually there.
I have a B26 with a 60" bucket. Does anyone know how much each bucket holds, or about how many buckets equals a yard?
   / How much does a B26 bucket hold? #2
I've got a 60" bucket on my Kioti 3054; it holds 1/3 yd when full. Don't know how that compares to a Kubota, but must be in the ball park
   / How much does a B26 bucket hold? #3
Went I went looking for a B26 I looked high and low for the very same answer. Seems like a straightforward question but I couldn't find the answer anywhere. The best guesstimate I got from a dealer was anywhere from 1/3rd to 1/2 yard but that depends on if the load is heaped or not.
You could also take one for the team and dig a bucket load, dump it and then shovel the load into a known sized container and let us know....:)
You'd think Kubota would have the capacity on their spec sheet. :confused2:
1/3rd of a yard sounds about right though.
   / How much does a B26 bucket hold? #4
The operators manual has this info... for some reason Kubota doesn't put this info on their published specs.
The L39 is 12 cu-ft struck (i.e. flat, non-heaped).
A yard is 27 cu-ft, so I'd expect the B26 in the 1/4 yard struck, and closer to 1/3 when heaped.
Ok I found it in the manual. Its between 11.2 and 13.? depending if its struck or heaped. So thats just under 1/2 yd, correct? I got scared when I read 1/4 yd. I have 18 yds to move, quite a distance. That would have been 72 trips. At almost 1/2 yd it cuts it down to about 40. :D
   / How much does a B26 bucket hold? #6
Yep, thats about 1/2 yard.... interesting, same as that L39.
UNUSED FUTURE DIE CAST RC EXCAVATOR TOY (A51243)
UNUSED FUTURE DIE...
3400 (A47384)
3400 (A47384)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
2019 JOHN DEERE XUV855M GATOR (A51243)
2019 JOHN DEERE...
