Loader How much can I lift?
   / How much can I lift? #1
suntreemcanic
Sisters, Oregon
Kabota B7800 HSD
I hope I am in the right forum. I take care of a Landtrac Model 360DTC tractor for a man who removes snow from driveways during the winter. He mounts a front end loader on it during the summer and moves around gravel with it. He said I could use it to move some logs. He does not have any manuals with it and the dealer who sold it is out of business. Does anyone know how much this tractor will lift with the front end loader? This will determine how long I can cut the logs. Thank you in advance.
   / How much can I lift? #2
you'll want to get weight on the 3ph.... Likely you'll need it...you need sufficient rear weight such that when you chain the FEL to an immovable object and try to lift it the FEL hydraulic relief will pop before the rear wheels leave the ground.
If you set the tractor up this way, you are at a reasonable weight safety point and can cut length of wood to match FEL lift capacity and still transport a full FEL load safely. Carry a full FEL about 6 inches off the ground. This way, if you hit a bump it will still stay under control, not start rocking violently back and forth.
   / How much can I lift? #3
That's good advice, but he wants to find out the lift capacity.
   / How much can I lift? #4
I thought he was seeking to determine the max log length he could in reality safely carry given wood density / cubic foot and the log's trapezoidal cylinder dimensional characteristics.:thumbsup:
   / How much can I lift? #5
Trapezoidal cylinder dimensional characteristics.:confused2:
Refering to the fact that the log is smaller diameter at one end than the other?
   / How much can I lift? #6
I have a Farmtrac model 360 DTC with a model 5145 loader, I'm guessing the loader you are inquiring about is the same one,my spec sheet says lift capacity at pivot points is 2100 lbs, breakout force 2600 lbs, hope this helps. Charlie.
   / How much can I lift? #7
I have a 390HST with 5140M. The specs on it are:
1600lb lift capacity at full height
3300lb breakout force
390 HST tractor is rated for 2976lb lift capacity for hydraulic system.
I have had a box blade on the back and almost tipped the tractor with so much weight in the bucket (wet dirt/mud). The only thing I have broken thus far are the two bolts that attach the loader frame to the tractor frame in the front (two on each side). I snapped two clean off while lifting some mud trying to clean out our pasture. The bolts holding the loader frame to the tractor frame come loose often, so check them regularly. I think the bolts may have been a tad loose which probably contributed to them snapping.
Matt
   / How much can I lift? #8
Matt
Keep in mind that figure of 2976 lb lift capacity is for your 3pt hitch which is the same as the 360 DTC.:thumbsup:
I do not intend to lift the logs more than 12 inches off the ground. What does the term "breakout" mean in comparison to lift weight. I want to saw my logs maximum length for weight that I can lift. The largest is 32 inches at the but.
   / How much can I lift? #10
Shearing the bolts that hold the sub frames to the tractor was an issue with Farmtrac Loaders. That issue was never correctly addressed by them. Some of my customers have installed channels from the sub frame to the final drives on the rear axles. The Great Bend loaders that I use to sell, already had that frame member on the loader. They don't shear the bolts off at the sub frame. Pushing on the bolts was a bad design from the start. The loader sub frame pressure points should be mounted on the front, mid , and rear of the tractor. Also remember, the loader is not designed to do heavy digging. Use a rear tine box blade to lossen soil first, then scoop it up with the bucket. Farm equipment dealers won't tell you this for fear of loosing a sale. As far as lifting, the hydraulics of the tractor do have the ability to lift the rear tires off the ground with a heavy object in or attached to the bucket. The weight cap. that are used at the piviot points are correct that were refered to above. All tractor lifting cap will changed with age of the unit. Remember, saftey and common sence will have to be used when determining lifting cap. of your tractors loader.
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
