How many solar panels
   / How many solar panels #1
RidgeTopWVA
John Deere 4400
How many solar panels would it take to run a window air conditioner ?
   / How many solar panels #2
Will Prowse and CheapRV Living have a couple of youtube videos on this. Depends on the size of the window unit and how much start up power is required. The solar panels are relatively cheap. The storage batteries aren't.
   / How many solar panels #3
Maybe only one of you have a big enough battery and you don’t want to run it often. If you mean how many will it take to run the AC directly from the panels, that’s almost impossible. Each panel only produces about .5 volts with varying watts depending on the size of panel. Really hard to get the power you need without a battery (bank) as ACs have pretty significant starting draws and are fairly power hungry in general.
   / How many solar panels #4
0.5V??
Panels on my shop at 44VDC open circuit, 37VDC loaded.
Each string coming into inverter is ~ 530VDC open, 450VDC loaded
   / How many solar panels #5
0.5V??
Key word, panels. What is the cell voltage in your panels? It’s going to be between .5v and .6v. 37vdc is a sum of the output from the number of cells and number of panels. You obviously invested a lot in the system, so you probably understand this.
It doesnt sound feasible.
   / How many solar panels #7
You wrote 'panel' in your initial reply, instead of cells. Thats where the confusion came in.
   / How many solar panels #9
it doesn't matter, he's wasting people's time with his antics. no one gives a crap about cell voltage, as its completely irrelevant.
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2008 GREAT DANE 53x102 DRY VAN (A53426)
2008 GREAT DANE...
2022 Big Tex 22GN-35BK+5MR 40ft 12 Ton T/A Gooseneck Equipment Trailer (A51692)
2022 Big Tex...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
