How many SCVs / remotes required for...?
   / How many SCVs / remotes required for...? #1
guest223
MO
None
Looking at purchasing a 5055e or 5065e. Future implements include:
  • loader (possible float)
  • rear blade
  • box blade
  • small hay rake
  • square bailer
  • possible front snow plow
  • possible backhoe
How many minimum remotes/quick-connects/SCVs are required, and where would they be mounted? Thanks, guys.
   / How many SCVs / remotes required for...? #2
For the loader there will be mid mount couplers on the right side of the tractor. Then you will probably only be able to get 2 rear scv's for the rear of the tractor. I've got a 5103 Deere and it only came with 1 rear remote and I bought a second and put it on myself. I haven't looked at the new models real close but I don't think there's enough room for more than 2 rear remotes because of how the valves stack together. If you get a rear blade get one with hydraulic title and angle , you won't regret it. That would take 2 remotes for that. I don't know about the backhoe how many it would require to work it. A hay rake and square bailey don't require remotes to run. Box blades could use 1 remote if you get one with hydraulic rippers.
   / How many SCVs / remotes required for...? #3
If go to Deere.com and build one you can only get 2 sets of rear remotes. I would get 2 sets because they will cost you much more to add later. I'd make sure to get one set with Float.
   / How many SCVs / remotes required for...? #4
Seems you can never have enough!
I wonder why Europe has been so far ahead of us in this area. They would probably laugh at what we get as standard equipment!
Thanks, guys - would any additional hydraulics be required for a front snow plow (to angle it)?
   / How many SCVs / remotes required for...? #6
I have a electric valve on my JD valve stack that works the (loader) blade/grapple, whatever ou have out front. It is an on/off type valve with a toggle switch on your loader lever, so you cannot feather it.
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
WESSEX CHT-100R-E LOT IDENTIFIER 222 (A53084)
WESSEX CHT-100R-E...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
