DJP
I also make the mistake and removed the wrong filter, the long filter, which I believe is the Hydraulic oil filter. Can I just refill the new one and tighten it back on, or did I loose some hydraulic oil and need to add more hydraulic oil? Where is the hydraulic oil stick to check the hydraulic oil level. I think I have found it but not sure, I have the 2002 Mahindra 4500 two wheel drive, I found a square bolt below/behind the driver sit on the back right, is that the hydraulic stick. What kind of hydraulic oil should I buy type and #? Also do I add the tractor oil in the same hole where the oil stick is?
