How many Hydraulic lines on a 3pt implement?
   / How many Hydraulic lines on a 3pt implement? #1
Richard1942
California, KY
Ford 3000 Gas
I have a 1966 Ford 3000 Tractor. I rented a lime spreader to lime my pastures. It had two hydraulic lines on it , but, my tractor only had one line for the 3pt implement. My friend spread the material with a larger Kabota.
My questions are:
1. Is it possible to use such an implement with only one line?
2. Is there an after-market kit that would modify my tractor for two-line implements?
I am sure that I am not the first to encounter this problem...I'm hoping someone can help.
Thanks, Richard1942
   / How many Hydraulic lines on a 3pt implement? #2
If you only use one hydraulic line, you will lose the use of the function that the other hydraulic line controls. You can definitely get aftermarket kits to add more rear hydraulic remotes.
   / How many Hydraulic lines on a 3pt implement? #3
Your tractor has "one way" hydraulics. It will force a cylinder one direction and then relies on load pressure to force it the other. So for a wheel disc, or wheel field cultivator for example, your hydraulics will lift the implement off the ground and depend on gravity to lower it.
As for question 2, that one's beyond me. Hopefully JJ will see this and answer that. He's my "go to" guy for hydraulic issues.
   / How many Hydraulic lines on a 3pt implement? #4
Why not install a new remotes that will do what you want. You can set up your valve to include things like , float, detent, motor control, SA cyl, DA cyl, etc.
It appears your tractor is setup for a SA cyl.
A single hyd line can run a SA cyl, or run a hyd motor. The motor return goes to tank.
Your hydraulics:
Hydraulics:
Type: open center
Pressure: 2500 psi [172.4 bar]
Pump flow: 5 gpm [18.9 lpm]
Steering flow: 4.25 gpm [16.1 lpm]
Steering press.: 600 psi [41.4 bar]
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2008 New Holland L175 (A47477)
2008 New Holland...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
60in Forklift Forks (A52378)
60in Forklift...
