Rotary Cutter how many hp?
   / how many hp? #1
Debbie Ra
Ford 9n
how many hps do I need on my tractor to operate a 5' bush hog?
   / how many hp? #2
Most recommendations I've seen call for a minimum of 20hp at the PTO. That usually means about 25hp overall.
Joe
   / how many hp? #3
Depends somewhat on what you cut, and how fast you want to drive. If the tractor's engine is bogging down, you'll have to slow down or only use 4 feet instead of the full 5' width... I use a 5' with 23 hp but I only cut in the winter, when it's dried out... only time I have to slow down is going up hill.
If you plan to be cutting thick grass or small trees, again, take smaller "bites" or go slower.
   / how many hp? #4
The rule of thumb is each foot of width requires 5 Hp at the PTO as a minimum, not engine hp.:thumbsup:
   / how many hp? #5
I've got 25 or so at the PTO for mine, and unless I'm cutting saplings, I can pretty much top out in low range without any issues in weeds beyond the top of the hood
   / how many hp? #6
I would rather see you use a 5 foot flail mower with grass knives from caroni.
My dad had a 6 foot JD flailmower with grass knives on his Ford Jubilee with no issues at all, I wish he had not sold it years ago. your 9N will breeze with a 4-5 foot flail mower with grass knives.
leonz
   / how many hp? #7
I have a B3030 that I use to pull a 5 foot Bush Hog through areas with tall (6 plus foot) sapplings and typical field growth. The tractor is rated at 23 PTO HP at 2600 RPM. When I am bush hogging, I run the tractor at 1800 to 2200 RPM and it gets the job done with ease. I do not have a HP/torque curve for my engine so I don't know what the PTO HP is at these operating RPMs.
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
4' x 6' Tilt Trailer (A50515)
4' x 6' Tilt...
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
2020 ISUZU NPR 18FT BOX TRUCK (A52141)
2020 ISUZU NPR...
1986 Diesel C70 Grain Truck (A50514)
1986 Diesel C70...
