How Many HP for this Disc Harrow?
   / How Many HP for this Disc Harrow? #1
kvmapr
Bronze Member
West Virginia
Jinma 254
I just saw a "pull-type" disc on Craigslist. And while I don't have the budget to pick this up (although it's going for a decent price, assuming it's in good enough shape) I'm wondering if my 25hp 4WD Jinma would be up to the task (should I ever find a similar disc).
What do you think? Take a look at it here:
Harrow, corn chopper & disc plow
I'm sure this thing won't last long.
kvmapr
   / How Many HP for this Disc Harrow? #2
I will jump in. If you are pulling that over some hard ground to break it up you will probably be able to pull it. If the ground has been plowed and is loose you might mave some trouble. I have a 27hp with loaded rear tires and pull a 6.5' 3pt disc. On hare ground it is very easy. When I disced the plowed stuff I was starting to meet its limits. That is in a very sandy soil.
   / How Many HP for this Disc Harrow? #3
If you put some weight on it so it will do some good you may be a touch shy of sufficient tractor. :D
If you want to use it for a harrow no problem.:D
That's encouraging. I would not be attempting any deep tilling with something like that. Just turning the garden each spring to bust the surface a bit. Where it would get the most use is up on my old meadow, where I need to bust up the sod a bit before planting trees (for a tree farm). I figure with enough weight and a few passes I should be able to chop the roots of the sod up enough to keep it down while the trees take hold.
kvmapr
   / How Many HP for this Disc Harrow? #5
Wow.. good prices.
I have pulled 6.5' dual ganged dis of the 3pt style with a ford N.. but in soft soil it's a workout.
I'd guess your tractor would also be ont he edge of ok.. with soil type being the variable. 4wd is a big +
Soundguy
   / How Many HP for this Disc Harrow? #6
kvmapr:
You have come up with some pretty good "finds" :). Your rear blade was a great score :D. I thought wifey set some "limits" on your attachment acquisitions ;). Jay
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
