How many hours on your Yanmar?
   / How many hours on your Yanmar? #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T62, MT55, E42R, E10, John Deere 4100
Saw a similar thread in the Kioti Forums and figured it would work out well in the Yanmar forums. How many hours does your tractor have on it? What have you added to customize your tractor? Pictures welcome. :thumbsup:
My YM169D has a little over 1110 hours on it, still runs and works great. Very few issues with it, has been a great first tractor. :thumbsup: As far as customizing goes, I have added a front grill guard and added telescopic lower links to the 3 point hitch to achieve better lift heights.
   / How many hours on your Yanmar? #2
This one is going to be all over the place. Us guys with the older 3 didgit hour meter have no idea what the hours are? Mine says like 110is or something i think? Im not really sure, but i got it as a recon and had 19 hours or something on it. I have no idea how many hours are on it. Even if i bought it as is with the meter reading 110 today you have no idea of knowing if that is 1110 or 2110 or even more.
   / How many hours on your Yanmar? #3
336d turned 1552 hrs today,
almost 50 degrees today in CT-come on spring ..................
   / How many hours on your Yanmar? #4
YM2002d Vietnam refurb 3012 hours. 1st picture is hydraulic for cement mixer lift cylinder. 2nd picture of my el cheepo winch. 3rd and 4th pictures of my latest tool box re do. 5th picture is my muffler re route.
   / How many hours on your Yanmar? #6
'87 276D... 1040 hours. Love it. Punches way above it's weight.
   / How many hours on your Yanmar? #7
It's not mine but I have a friend with a Deere F series mower w/ 22 HP Yanmar 3 cylinder. He bought it from his employer, who bought it new and it now has 12,000+ Hrs and still running. He put new rings in it last year and that's the only work the engine has ever had on it.
   / How many hours on your Yanmar? #8
1200, 2200, unknown, as only have the 3 digit meter as well. I expect it will last at least 12,000 before any work is needed. I am also a sail boater, and in the marine Yanmars, 12-20K hours is normal. I expect the tractors to last that long as well.
   / How many hours on your Yanmar? #9
My Yanmars:
YM240: x402
YM240D: x299
YM2000: x562
YM186D: 705 (Acquired from original owner who says hours were accurate)
YM1401D: x570
I'm suspicious that the hours on the YM240D and the YM2000 may actually be correct readings. Both of them bang instantly to life if there is enough power to the starter to spin the flywheel all the way through the compression stroke. Even with a nearly dead battery I can get them to fire up in "cold" (down to 40ish degrees) weather, without any thermostart or other tricks. The Y2000 is astonishing to me every time I fire it: the starter can just barely be turning the engine, but if I time it correctly I can close the compression release, the piston will b a r e l y get to the top of the compression stroke, and it will clank to life.
The 240 is almost certainly 1402 or 2402, or more. It still runs fine, but needs more speed from the starter and a few revolutions to build heat in the cylinder head before it will fire. The 1401D and 186D seem to be about the same; the 1401D may actually have only 570 hours; it starts easily, easier than the 186D, even, and they share the same motor.
Having said all that, it's much more likely that the ease of starting is much more closely tied to air filtration quality throughout the history of the machine than the absolute number of hours in operation.
   / How many hours on your Yanmar? #10
Anywhere from 227 to close to 700... Same tractors, all run the same. :D
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
PORTABLE UP RIGHT FUEL TANK (A51248)
PORTABLE UP RIGHT...
(INOP) KUBOTA B7510 TRACTOR (A51247)
(INOP) KUBOTA...
