How many gpm to front of 4720 scv ?
   / How many gpm to front of 4720 scv ? #1
Ramairfreak98ss
Columbus, NJ
Ferris/Simplicity/John Deere
I have the front loader mounted boom couplers on a 3rd diverter scv valve for future grapple type bucket and all. Im looking at a skid mounted hydraulic boom breaker attachment that requires 6gpm from Deere worksite pro attachments. Is the flow through this sufficient or is it very minimal like 2gpm or ONLY for the grapple hydraulics?
   / How many gpm to front of 4720 scv ? #2
It will be whatever your implement pump is rated for, so according to the specs its 12 GPM:
Implement 12.0 (45.3)
I don't think I would use one on my tractor though-they will beat it to death!
well thats more than i thought it would have, you mean the smaller ones even will shake it like ****? Deeres smallest model is only about 400lbs weight for the whole unit. It would be used for breaking 4" concrete and or asphalt for driveway removal by means of bucket.
Not often would i use this but if its gonna be terrible on the machine i wont even bother.
   / How many gpm to front of 4720 scv ? #4
I think the shock load is the problem. It's very hard on the pins and bushings.
How much is the unit? Have you check the price of a rental SSL with a breaker? I know I rented a Bobcat 763? with a Rockhound for under $300 a day to put my lawn in...
   / How many gpm to front of 4720 scv ? #5
Pretty rough duty on a "green" FEL. Not recommended... - IMO. Although, with bucket teeth on your loader; the asphalt removal might not be that difficult of a chore.
And depending upon the overall size of the concrete; you might be able to lift the slab up from the bottom and drag it (or lift it) with a chain or strap and your FEL. Sometimes, just lifting the slab up will cause it to break and split into more manageable chunks (if they're not reinforced with major amounts of wire or rebar).
Might not need the hydraulic breaker.
AKfish
   / How many gpm to front of 4720 scv ? #6
I've done some sidewalk removal with my little 2305, just cut it in chunks with a saw and moved it with the tractor.
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
202421 (A51406)
202421 (A51406)
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
