Tires How many gallons do rear tires hold?
   / How many gallons do rear tires hold? #21
Yeah I wasnt gonna do the front tires I just copied and pasted the tires sizes from their website. Thanks for the info that sure is alot of bug juice!!:eek:
   / How many gallons do rear tires hold? #22
I just finsihed loading the rear tires with -20* WW, it went ok for the most part but was certainly a pain in the A**!! haha
   / How many gallons do rear tires hold? #23
I believe I put about 29 gallons per tire. I got that figure from one of the tire website for that tire size for my CT225, same tire as you. I used 1.64 a gallon -20 WW fluid, I think that is cheaper than antifreeze. One bit of advise, re-seat those beads good before you start, I had some leaks and I had to raise my pressures to stop them and them add some more fluid. I lowered my pressures back down and no leaks so far. Get a good pump, my drill pump was a pain.
what does 1.64 a gallon mean ?
   / How many gallons do rear tires hold? #24
   / How many gallons do rear tires hold? #25
Yep, $1.64 from a wholsaler got a 55 gallon drum plus some loose gallons at wally world.
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
KING KUTTER 5' DISC BLADE W/ 1PT HITCH (A52708)
KING KUTTER 5'...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A55973)
2006 Ford F-750...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(INOP) FARMALL TRACTOR (A52708)
(INOP) FARMALL...
2009 International Workstar 7500 T/A Terex Commander C5045 Digger Derrick Truck (A55973)
2009 International...
