How long to decide on which tractor to buy?
   / How long to decide on which tractor to buy? #1
Rumgone01
SAME 90HP
Hi diesel burners
I'm considering buying a new tractor. My SAME 90 is ready for retirement. Its been on my mind for a month or so. interested in other peoples experiences. How long did it take you to work out which tractor to buy? And where did you do your research? on-line, neighbours, friends, family, farm equipment shows, dealers ?
Anyone like to share their experience?
regards
   / How long to decide on which tractor to buy? #2
About ten minutes of sitting in the Massey 1742, after operating the old Ford 3000 on a half mile driveway in the winter .
   / How long to decide on which tractor to buy? #3
I did spec researching online and then spend several days at dealerships to see if I liked the tractors that had the desired specs. Probably took me two weeks to make a decision.
   / How long to decide on which tractor to buy? #4
I researched it off and on for 5 months. Between that time, I had many other projects occurring simultaneously.
   / How long to decide on which tractor to buy? #5
Hi diesel burners
regards
On/off looked at tractors online for a year. Created false expectation in my head of what I was going to get. Started visiting tractor boards for a couple months to learn more and get an idea of what size I should look at. Talked to the wife and got her on board with getting a tractor for our situation. (I included the wife since we always make large purchases in agreement together) We spent 2 months visiting tractor dealerships because we could only go look on Saturdays and most tractor dealers are only open until noon - 2pm on Saturdays. Made my wife test drive them all as well. She liked the tractor we ended up buying and refused to test drive the Kioti's (last model we looked at) because she wanted to get the NH/Case model.
A couple of things I learned:
1. Shopping for tractors is pretty much a journey and your needs/expectations will evolve as you compare models.
2. Be open-minded. Look at every brand and model you can - it is worth it to get the right tractor for your situation
3. If buying new and financing the higher price tractor might be cheaper with lower financing rates
4. It's a large purchase - don't be afraid to make the dealer earn your business and be competitive in price.
Good luck with your search :)
   / How long to decide on which tractor to buy? #6
I took about 10 minutes. I saw the Kubota BX at a local fair, and thought it was a great price for what you. Wasn’t even looking for a tractor until I saw the BX.
   / How long to decide on which tractor to buy? #7
The first bit of research I did was to ask neighbours and in the pub as to who they would recommend as the best Dealer(s), reputation-wise. In my case, the name that constantly came up was JD.
I had zero knowledge about tractors or what I would need, so I grabbed an old duffer Mate and we set off for the JD Dealership in Longford in order to get there at just after opening hours. The salesman, Jamie, had all the time in the world for me... asked me what I needed the tractor to do, what the 'biggest' regular task was (moving/stacking round bales) Of course, the size (hp) of tractor went up from my naive estimation of a low 2xxx Series to a high 3xxx Series.
Jamie then thought a bit, tapped on his computer and brought up the 4105, bare bones rig but with more hp and at a lower price than the 3xxx Series. There wan't a 4105 on the lot but he simply called up a previous customer who did have one and Jamie then drove us out to that property so that I could try it out. (How's that for customer relationships,eh?) My Mate (Dougie) nodded and I bought it then and there.
Your local knowledge and local 'network' of friends/neighbours will steer you to where your local area's best dealership/tractor is.
   / How long to decide on which tractor to buy? #8
Well - in my situation it is sort of a two part question. I owned my first tractor for 27 years - Ford 1710 4WD - bought new in 1982. Traded in on my new 2009 Kubota M6040 in 2009.
I knew for the last three or four years that in order to get going on the remaining projects around the property - I was going to need a larger tractor - larger & different implements. In the 27 years the local dealer that I bought the Ford from had changed to Kubota.
So...... down to the dealer - WoW! look at all the shiny new orange tractors. After using the Ford for 27 years - I had a good idea of what I needed vs what I wanted.
The 2009 Kubota M6040 with hydraulic shuttle was what I needed. It is large enough to handle the class two implements that I will use for the remaining projects around here. The dealer had M5040, M6040 & M7040 on the lot for me to look at. The M6040 was the only open station unit. Other two were cabbed.
It would have been nice to get a cab but after 27 years with an open station Ford - I knew that a cab was not the way to go. Too much going between and around giant old Ponderosa pines. Any cab would suffer almost immediate damage. Besides - except for a few days - summer weather is most enjoyable here. And for those really cold plowing days in the winter - its Eddie Bauer from the bottom of my feet to the top of my head.
I have absolutely no regrets choosing the brand and model of tractor I have. Smaller would not handle the class two implements I use - bigger would simply be too big to navigate around the property with all my trees.
Thirty seven years out here - never once been able to find a used implement that would be anything I need. Always have purchased new - class two implements ARE expensive but with proper use and care - I expect they will last a lifetime.
   / How long to decide on which tractor to buy? #9
I am an analytical type but also wanted a well rounded opinion. So I did several things such as made spreadsheets to compare the raw numbers, talked to local people I knew who had tractors, went to dealerships for info and to try them, etc. My wife being a bit skeptical insisted I get something with resale value in case it didn't ultimately work for me. I spent a good month on it actively.
For me, it came down to Kubota and Kioti as they were local dealers - I knew I was going to lean on my dealers for service and advice. I chose the Kubota because of the dealership.
Hindsight tells me I got several things wrong due to inexperience though. I bought a BX25 as I knew I would be mowing 90% of the time with it. The backhoe on the BX25 appealed to the "That's cool!" factor in me but in reality, I've used it maybe three times. What I should have gotten was a B26 or B33 with a cab.
   / How long to decide on which tractor to buy? #10
JFoy - do not be surprised when I say - - I've heard your comments regarding the backhoe attachment MANY times. And that is only from those who are willing to admit that the backhoe was an expensive, seldom used addition.
Fortunately - after selling the implement - my mistake only cost me $1000. I purchased a Land Pride RB3596 rear blade. Absolutely nothing wrong with the blade - EXCEPT, it was WAY to light for summer driveway maintenance.
I have a mile long gravel driveway that turns to concrete after the spring rains. The 565 pound Land Pride just would not do the job - too light.
I sold it and purchased a new Rhino 950 at 1100 pounds. It definitely has the required weight to do the job.
378633 (A51573)
378633 (A51573)
MONOSEM NG-3 LOT NUMBER 257 (A53084)
MONOSEM NG-3 LOT...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
