Looking at getting a Durango to replace the wife's Dodge 1500 (regular cab, long bed), we need something that is a little bit more of a family car, does anyone have a 1998-2003 (or whenever they switched to the new body style) Durango with a V6 or a 318 in it? if so, what kind of mileage do you get with it? how well has it held up?
Aaron Z
I had a 2000 model year 4x4 Durango with a 4.7L engine in it. It had about 80k miles on it when I sold it and it held up pretty well. Then I got a 2005 model with the new body style and a 5.7L engine in it.
I tow an enclosed utility trailer that weights 3500# and both vehicles do a fine job with that. However the rear springs on the 2000MY are pretty soft and it squatted a lot with 500 or so pounds of tongue weight.
I once towed my 37 ft 5800# travel trailer with the 2000MY Durango and it was about the scariest thing that I ever did. I only had to go 60 miles on the highway and I didn't think that it would be a big deal. While it's true that that is a big trailer and I did not have a load equalizing hitch, the vehicle squatted a lot, would sway side to side and could never figure out what gear to be in at 60MPH. It would drop down one and rev to 4000rpm, then upshift and slow down, down, up... repeat. Even with the tow mode on. After running over a groved section of road it started to yaw back and forth and the light rear suspension made the vehicle pitch a lot. I really thought that I was going to lose it. It was a heart pounding "OH my god" moment.
Now the 2005 has a totally different suspension and a slightly longer wheel base. That in itself make it a much better tow vehicle. I've towed the travel trailer with it and there is no tendency to sway. And it is not very sensitive to tongue weight (like the 2000MY was). Plus the 5.7L gives me the same average fuel economy as the old 4.7L at about 14 city and 18 highway (75MPH). It even gets about 1MPG better then the 4.7L towing the 3500# trailer at 70MPH.
If you are towing a small trailer, either will work. If you have something larger, like a travel trailer, the 2000MY is a poor choice.
I've had both for about 80,000 miles and 4 years. The 2000MY had more comfortable seats, but the 2005 is head a shoulders a better vehicle.
There is a special additive that needs to go into the rear end if you are going to tow. The 2005 was "supposed" to have it, and yet the rear end pinon bearing went out as about 50K miles. Luckily it was still under warranty.
Stuart
