Oil & Fuel How important are 300 hour HST oil changes for Kubota B7510 used as a mower?
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Coming up to 600 hours on my Kubota B7510 which runs a 5' belly mower and a 4' bush hog. When I changed the oil and filters at 300 hours there was no evidence whatever of anything but pristine oil and clean drain plugs. Have all of those old HST Kubotas really had their oil changed every 300 hours?
The reason I ask is that I never changed the oil in the running gear of my Toyota 4Runner, and it ran well over 400,000 km without a whimper, notwithstanding Toyota's stern requirements for expensive service. My 4WD Tacoma so far is the same. All I have done is grease them faithfully.
I'm willing to do the maintenance if it does any good, but I think I'll skip that long strainer underneath.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #2
You live in Ontario, we live in a moist environment, the biggest hazard is water accumulation from condensation if the equipment is stored in sub-zero temps during the winter. If it was stored in a heated garage that's a completely different thing. You can see the presence of water in your HST if it appears milky in colour after you run it for a while. If you were operating the equipment in the winter the problems would be far greater and become apparent as ice crystals would clog the filters and starve the pump for oil. (they make nasty noises when that starts to happen) You might not even notice it in the summer although water getting into places that should only contain oil is not a particularly good thing, it makes things rust. Putting grease into fittings is equally important for the same reason, it not only lubricates moving parts but it also displaces any water that has collected in places that it shouldn't be.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #3
Trust but verify.
Pull a sample and send it to a Used Oil Analysis site (I use blackstone).
I was advised here by many "forget the expense, just change the oil" at EVERY 3,000 to 5,000 miles on my F350. I sent off samples every once and a while after I changed to T6, finally changed it at 20,000, might have been able to go another 5,000. Every oil change would have been about $75 for oil and filter.
I run T6 because I don't have a functioning block heater and it starts well cold.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #4
Pretty sure he is referring to the hydraulic oil in the hydrostatic transmission and not the engine oil. T6 wouldn't be so good for that.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #5
I KNOW he's referring to the HST, but the principle of "Trust but verify" remains the same. If he THINKS his oil is good a UOA would confirm. My point was NOT to put T6 in instead of SUDT.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #6
Ran my last HST tractor over 4000 hrs. and maybe changed the trans hydraulic oil 3 times filter 5 or 6. Used the tractor nearly every day summer and winter sold it 2 years ago and it's still going strong. I'm not saying it was good practice just that I think every 300 hrs. is excessive.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #7
Yup, and if the average TBN'er who puts on 200 hours a year OR LESS ran their tractor for 7 years they might have sold it. 300 hours is a mfg CTA action for warrantied equipment.
If your equipment is OUT of warranty why follow their rules for maintenance when you can check if it is needed?
Some posters here advocate changing the fluids annually. That may be fine for their usage but not for my wallet. A UOA is relatively cheap compared to a complete HST fluid change.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #8
... Have all of those old HST Kubotas really had their oil changed every 300 hours? ...
The tractors stored in the cold and used for winter snow removal, probably yes, or they wouldn't move when you needed them the most. The lawn tractors like yours, probably no.
Engine oil analysis I totally get, but what would y'all expect an analysis to find in a sample of used hydraulic oil, other than water from condensation and possibly a very tiny amount of suspended solids that made it's way through the filters? The HST oil is not subjected to diesel combustion blow-by or extreme high temperatures and it's not lubricating an engines valve train.
Please don't take this wrong Billrog, but you live in the Okanagan valley and compared to eastern Ontario you live in the banana belt of Canada. The OP doesn't use his Kabota in winter, so he would not be seeing anywhere near the condensation accumulation that myself or anyone using their tractor for snow removal deal with every winter. Even less if it is stored in a heated garage over the winter months. If I want my tractor to function in the -20 to -30 degrees C that we see for 3 to 4 months of the year out here, it needs to have fresh hydraulic/transmission oil almost annually, once every 2 years at most ymmv. That's why my next house is going to have a heated garage ;)
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #9
... Engine oil analysis I totally get, but what would y'all expect an analysis to find in a sample of used hydraulic oil, other than water from condensation and possibly a very tiny amount of suspended solids that made it's way through the filters?
Similar stuff to what you would see in used engine oil analysis - primarily levels of wear metals, and additionally, the TAN (Total Acid Number) ... as well as any other contaminants (water, etc.)
Good idea to run a virgin (unused) sample of whatever hydraulic fluid you are running ... so that you have a baseline to compare an analyzed used sample to.
True ... but largely irrelevant.
   / How important are 300 hour HST oil changes for Kubota B7510 used as a mower? #10
Any respectable oil analysis lab will want to know what component the sample came from, hours/miles of use, etc and brand and viscosity of the oil. The findings will include any contaminants related to wear, moisture, other contaminants or additive breakdown. The results will give a clear indication whether the oil should be changed out or retained, especially when sampling is ongoing and a baseline has been established.
If you truly believe that HST oils are not subjected to high temps you lack an understanding of that type of system. Improper operational methods can result in high oil temps and temperature related oil and component failure.
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2015 Ford F-550 4x4 Knapheide Service Truck (A50323)
2015 Ford F-550...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2019 John Deere HPX 815E (A50121)
2019 John Deere...
