How I heat the 12x22 Garage/Shop
   / How I heat the 12x22 Garage/Shop #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
I heat this 12 x 22 room with this 30,000 BTU ventless wall heater.
It's mounted to the back end wall about 16'' above the floor.
The fan is above the heater near the ceiling and tilts slightly downward so as to blow the warmer air above the heater down to the floor and toward the front of the room.
Attached to the 2x4 under the fan is a bracket I made out of a yard stick.
(I love making brackets with aluminum yard sticks as you never have to measure it to get the length you want because it's already marked.)
On the lower end of the bracket is a thermostat from a forced air furnace that's used to control the blower fan on/off cycles in virtually all such furnaces.
I wired the thermostat into the fan cord.
The thermostat is adjustable and can be set at different temperatures.
I think I got it from a heating contractor for about $5.00.
The thermostat is the key for any success for the fan because if the fan was to run constantly it would always be blowing cold air around.
The purpose of the fan is to move warm air.
It can't do that without the thermostat.
Toro Mower (A50324)
Toro Mower (A50324)
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
