How hard is it to detach and reattach an FEL on a Kioti CK30
   / How hard is it to detach and reattach an FEL on a Kioti CK30 #1
bzimmel
Buford, GA
Kioti CK30
I've never tried this, but thought I'd like to so I can get into some tight spaces in my woods when clearing and making plots. Is this a pain in the ***** to do?
   / How hard is it to detach and reattach an FEL on a Kioti CK30 #2
:welcome:
   / How hard is it to detach and reattach an FEL on a Kioti CK30 #3
Coming off is easy, going back on can be more challenging. Set the loader on a hard fairly level surface so the legs don't settle in. Use the bucket curl/dump to tip the loader arms in and out of the locking frame.
   / How hard is it to detach and reattach an FEL on a Kioti CK30 #4
Also be sure to bleed pressure on the quick disconnects before disconnecting, otherwise reconnecting can be a PITA.
Thanks for the welcome, Murphy. For the other guys, do you know of a youtube demo on this? I find some for the Kubota, but I'm sure the arms and locking pins and such are different. Thanks much!
   / How hard is it to detach and reattach an FEL on a Kioti CK30 #6
I took the loader off my dk40 before the snow came so I could put the front mount blower on. I had to put the loader on last weekend and learned a couple things:
- A couple inches of packed snow and ice can make a difference.
- you need to be lined up almost square to the loader, if it wasn't frozen in the ground I could have bumped it a bit to bring it square to the tractor.
- clear the ice out of the loader frame pockets, that's where I REALLY got burnt.
- level ground is your friend.
In the end I got it on, but it was a bit of fight.
Jason
Cascade Hydraulic Grapple Excavator Attachment (A49346)
Cascade Hydraulic...
2008 GMC Yukon SLE 4x4 SUV (A48082)
2008 GMC Yukon SLE...
INTERNATIONAL 786 TRACTOR (A50459)
INTERNATIONAL 786...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A48837)
New/Unused 30ft x...
2022 Load Trail Trailer, VIN # 4ZEUT1827N1269100 (A48836)
2022 Load Trail...
2005 Ford F-350 4x4 Crew Cab 8ft Dump Truck (A48081)
2005 Ford F-350...
